.NET
2004 crashes when it reaches “AcadDoc.Utility.GetEntity “
0 REPLIES 0
Message 1 of 1
wcruz
231 Views, 0 Replies
I am working on a *.dll that runs under Autocad ( I load it using a lsp file ). The program runs fine under CAD Versions 2000, 2005 thru 2008. But when I run it under 2004, it gets crazy when it reaches the line of code show above. When I start the program, it shows the prompt "Select the MAIN piece Polyline:” but the cross hair disapears from the drawing area & if I click on any task @ my task manager, autocad 2004 closes automaticly. So there you have it, I have provided the piece of code up to the error, hopefully this helps. Thanks in advance for your help.
William
‘I have added acax16enu.tlb as my AutoCAD 2004 reference file
Imports AutoCAD
Sub Select_Plines()
Dim oEnt As AcadEntity
Dim vPick
Dim oRegions As Object
Dim oRegObjects(0) As AcadEntity
Dim CgLocation(0 To 2) As Double
Dim AcadRegion As AcadRegion, i As Long
Dim addRegion As Acad3DSolid
Dim F3D As Acad3DSolid
Dim Coll3D As New Collection
Dim CollRegion As New Collection
Dim CollThickness As New Collection
Dim CollEntity As New Collection
Dim yDist As Double
Dim x As Integer
Dim DimX As String
Dim DimY As String
Dim Diagonal As Double
Dim DiagonalFeet As String
Dim basePoint(0 To 2) As Double
Dim directionVec(0 To 2) As Double
Try
AcadApp = GetObject(, "AutoCAD.Application")
Catch
AcaDApplication = CreateObject("Autocad.Application") 'open AutoCAD
End Try
AcadDoc = AcadApp.ActiveDocument
Try
Retry:
oEnt = Nothing
vPick = Nothing
AcadApp.Visible = True
AcadDoc.Utility.InitializeUserInput(1, )
'SELECT THE PLINE
If x = 0 Then
‘IT STOPS WORKING WHEN IT REACHES THIS LINE OF CODE
AcadDoc.Utility.GetEntity(oEnt, vPick, " Select the MAIN piece Polyline: ")
Else
AcadDoc.Utility.GetEntity(oEnt, vPick, " Select additional Polylines (or Enter to continue): ")
End If
Catch
MsgBox(Err.Description)
End Try
0 REPLIES 0
”Boost
