.NET
.NET
6 Kudos
Post 1 of 6
1073741819 (0xc0000005) 'Access violation'.
1855 Views, 5 Replies
06-28-2013 04:33 AM
The program '[6352] acad.exe: Managed (v4.0.30319)' has exited with code -1073741819 (0xc0000005) 'Access violation'.
This is the last line from the output window. Before that, i have couple of warning about dispose call and first chance exceptions:
A first chance exception of type 'Autodesk.AutoCAD.Runtime.Exception' occurred in AcdbMgd.dll
Forgot to call Dispose? (Autodesk.AutoCAD.DatabaseServices.BlockTableRecord): DisposableWrapper
I have chacked all exceptions in the debug settings, but still no exception is thrown and autocad just falls down.
Any idea, how to catch this exception?
Just a guess, but this 'Looks' like the clasic .NET Dispose issue. You must Dispose of AutoCAD referanced objects explicetly. AutoCAD runs on a single thred; The .NET Garbage collector can call .Dispose from another thread, which is bad. Make sure you use 'Using' (For VB) the vars, or that you call dispose of them with a direct call of Dispose. This is usually a 'random'ish crash, can you reproduce it?
HomeBoy Out
Valued Contributor
11 Kudos
Post 2 of 6
Re: 1073741819 (0xc0000005) 'Access violation'.
06-28-2013 06:07 AM in reply to: matus.brlit
Your plugin runs in the same .NET AppDomain as Autocad so theoretically you should be able to catch all uncaught exceptions in an IExtensionApplication as such:
Public Sub Initialize() Implements _
        Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
            AddHandler AppDomain.CurrentDomain.FirstChanceException, AddressOf GlobalExHappened
            AddHandler AppDomain.CurrentDomain.UnhandledException, AddressOf UnhandledExHappened
 End Sub
    Public Sub GlobalExHappened(source As Object, e As FirstChanceExceptionEventArgs)
        log.FatalException(e.Exception)
    End Sub
    Public Sub UnhandledExHappened(source As Object, e As UnhandledExceptionEventArgs)
        log.FatalException(e)
    End Sub
Active Contributor
0 Kudos
Post 3 of 6
06-28-2013 05:52 PM in reply to: matus.brlit
HomeBoy Out
Active Contributor
0 Kudos
Post 4 of 6
06-28-2013 05:54 PM in reply to: sszabo
 End Sub
    End Sub
    End Sub
Cool, I did'nt know that! Thanks
HomeBoy Out
6 Kudos
Post 5 of 6
06-30-2013 11:34 PM in reply to: sszabo
thanks, cool tip
6 Kudos
Post 6 of 6
06-30-2013 11:41 PM in reply to: HomeBoyLV
thanks HomeBoy, you were right,
I found the cause after i read Kean's blog here: http://through-the-interface.typepad.com/through_the_interface/2008/06/cleaning-up-aft.html
I created a BlockTableRecord object, that I meant to use later, but not in all branches, so sometimes, it was not added to transaction and then AutoCAD crashed, when I closed the window. That's why it was hard to reproduce, because it didn't crash after the action, but when the garbage collector came in action, which was not after each close.
