when we import a ptx file into navisworks it has the wrong orientation, see attached picture. We then use a lot of time changing the orientation vector - but I would like to know if there are a way aroud this - f.x. by changing the default orientation vector for imported ptx files.
It is strange because when import the same ptx to other Autodesk porducts like, autocad, revit or recap - everything is orienteted correctly.
thanks
christian
Perhaps this is a possible workaround:
Create a separate, new NWF file
append all PTX files
Save as NWD
in the model you really want
append the NWD
then select it in the selection tree,
use File Units and Transform to change the rotation (90 about Y ore something like that)
