Hi Everyone,
Please help me on this, I'm trying to establesh sets on Navisworks to manage my work. my sets will be based on the "Mark" parameter but I can't see it with many other parameters!! I attached some photoes to ellustrate my problome.
Solved by Logan.Wallace. Go to Solution.
My first thoughts are to check in the Selection Tree and make sure you are selecting the right "Item". Depeneding on which level you select (Item, Category+Family, Geometry) you will be presented different parameters.
Another thing to check is to set your Selection Resolution to the desired level. This is done in the Home tab > Select&Search pulldown > Selection Resolution pulldown.
I added a couple quick screenshots of what my guess is; I hope that solves it for you!
