Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Whats happened to NWDOUT & NWNAVIGATOR in Navisworks Manage 2012
7 REPLIES 7
Message 1 of 8
ukdxb012
2581 Views, 7 Replies
I'm seeking some clarification...
I understand that the command 'NWDOUT' has been removed from the Civil 3D/ Navisworks Manage Interoperable workflow due to licencing issues. Has NWNAVIGATOR been removed also?
I currently have a copy of x64 Bit Civil 3D 2011 and 2012 on my machine with Navisworks Manage 2012 installed. In Civil 3D 2011 i can type in NWLOAD and everything appears to be fine. Same command in Civil 3D 2012 but get the 'unknown commad' issue. Why is this? Navisworks Manage 2012 was installed after both versions of Civil 3D...
If i was to load the *.arx manually what should i be looking for? All i can see is an export version .arx, which doesnt include NWNAVIGATOR, does anyone have any advice? Ami missing something doing a manual install?
Adding the .arx enables 'NWLOAD' and the 'NWOPT', 'NWCOUT' and 'NWOPTA.
What id expect is when installing Navisworks Manage 2012, it should associate itself with both versions of Civil 3D. Should that be the case?
Is it worth in my deployment images including Navisworks Exporters as a seperate install once the Civil deployment has been installed or repair / reinstall the Navisworks Manage Image after a new AutoCAD / Civil install?
Duncan
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
7 REPLIES 7
Message 2 of 8
JeffH_ADSK
in reply to: ukdxb012
Hi Duncan,
Navigator is indeed still part of Navisworks. It's bundled as a NET plugin, and should be located in the root directory of your AutoCAD vertical (of type DLL, not ARX). You can load it as you would any other NET plugin if for some reason the installer has failed to provide registration.
On that subject, the Navisworks installer can only install exporters for AutoCAD verticals it detects at install time. So if you install Civil 3D after Navisworks, it will not add exporters. A repair and then selecting the new plugins to add should solve this.
If the installer is still failing to find Civil 3D 2012 as a valid install target to update, I would recommend opening a support case so that this can be followed up.
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
Message 3 of 8
ukdxb012
in reply to: JeffH_ADSK
Jeff,
Thats great, thanks for clearing things up...
It does look as though when Navisworks Manage 2012 has been installed it hasnt automatically set up the dll for nwnavigator in Civil 3D 2012 but has in 2011. Just out of curiosity whats the name of the dll so i can search and confirm this.
Would you also know the paths also for 32 and 64 Bit?
Finally, i have AutoCAD 2011 and Civil 3D 2011 confuse the Navisworks Installer? Obviously Civil is built on AutoCAD but on my machine i have 2 versions. One using a licence of Civil and the other using standalone.
Duncan
Duncan Brannan
Twitter | LinkedIn
Message 4 of 8
dave.wolfe
Whats the name of the .Net dll to load for Navigator?
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 5 of 8
dave.wolfe
in reply to: dave.wolfe
Never mind.  NwNavigator.dll.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 6 of 8
This is a problem with plain Autocad as well.  All Navisworks menu picks work except for NWD Export.  Even Export Options work.  NWDOUT is "Unknow Command".  The ARX and the CUIX are loaded properly.  What is the problem???
Message 7 of 8
dembkod
mmhill,
Hello. NWDOUT is no longer a function available in the exporters, you will need to use NWCOUT.
There are a few functions you can utilize from within the AutoCADs.
If Navisworks is installed alongside the AutoCAD installation, you will have:
NWNAVIGATOR – to access the Navigator window in your AutoCAD instance.
NWLOAD – To access the Navisworks Switchback function. You manipulate your model in Navisworks and can switchback to a connected DWG model in AutoCAD to fix any issues.
With the exporters installed you also will have:
NWCOUT – Export your model to NWC format
NWOPT – check your exporter options
If these do not appear in your installation, it could be the order with which you installed the program. Navisworks installs these modules during the installation of the application, so if you install Navisworks before AutoCAD, it has nowhere to install the functions. You would uninstall and reinstall Navisworks to prime the installation of the functions.
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
http://beyonddesign.typepad.com/
David Dembkoski
Message 8 of 8
in reply to: dembkod
This discussion thread explains what has happen to NWOUT.
"Navis Manage 2012 NWDOUT will not work"
http://forums.autodesk.com/t5/Autodesk-Navisworks/Navis-Manage-2012-NWDOUT-will-not-work/m-p/3033672...
I have to agree with the last user in this thread.  The export was working great for us from Simulate 2011.  Autodesk, once again, has complicated our design process instead of making it more efficient.
Rail Community
