Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
What is Navisworks seeing that I can't?
1 REPLY 1
305 Views, 1 Reply
Using Navisworks Manage 2014.  I append a dwg.  Zoom-All.  My geometry shows up at the bottom right.  There's apparently something in the dwg way up in the upper left.  Open the dwg: Zoom Extents; Nothing there but what should be there.  Purge DGN linetypes.  Purge extended data (thanks for the exe Autodesk).  Purge everything else.  Wblock the whole drawing to a different filename.  Back to Navis; append the newly-purged drawing and Zoom-All...same thing.  My drawing is in the lower right corner.  Navis is apparently seeing something in the upper left which I can't seem to purge out, even with a wblock.
No, I can't atach the offending dwg file; I wish I could.  IP protection.  If I did that I'd lose my job.
Any suggestions on finding what is pushing my drawing in Navisworks down to the bottom right when I zoom-all?
Thank you for any help.
Erik
1 REPLY 1
Patrick_Aps_9121
Just some idea's
Try detaching all Xrefs of the DWG, if any are present
Try using version 2013 or 2012 of Navisworks, if you still have it.
Rail Community
