Hi,When I try to render my collection of Revit sketchup models, the 'floor' I've used to create a water level (from Revit) won't render and appears white, with no texture or waves etc. All the other model elements have rendered fine, even the sketchup faces have the proper materials rendering well, it's just the water. When I change the material type to something other than water, it's fine, but none of the types of water material work at all. Any ideas please?
Some of the materials are a bit wonky. If it is like the grass materials, the high reflectivity of the material makes it reflect like mirrors in low-angle shots but reasonably OK in high-angle shots. Either way, I don't think it will do waves/ripples/etc.
