I have saved viewports in Manage 2012 and exported the viewports as a viewport report. I want to know if it's possible to increase the size of the viewports? Right now they are very small and blurry, when team members enalrge the images from the html reports.
Any help would be greatly appreciated.
Thanks in advance,
Mike
Solved by lee.mullin. Go to Solution.
When opening Options hold shift down which takes you to the Advanced Options, then go to Interface > Viewpoint defaults, this will allow you to change the default Viewpoint size.
Lee,
It appears that this functionality is no longer working in Navisworks 2013. Will there be a hotfix to restore it? (Or is there another workaround?) It was very useful in both 2011 and 2012 for coordination.
Any suggestions you have would be greatly appreciated.
Kyle
This seems to work correctly on testing. Ensure you go into Advanced options by holding Shift when opening options. Then Interface > Viewpoint Defaults > Viewpoints Report.
Also ensure you have SP1 installed as this is what I tested with
usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19840757&linkID=10382102
Lee,
Thanks for the workaround. I'd mostly been using it with very large (6300 x 4300) pixel exports of single images, so using Output > Image was my preferred method (rather than exporting all viewpoints). However, your suggestion should work in a pinch.
Kyle
