Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
view setting in navisworks
3 REPLIES 3
sabatierae
344 Views, 3 Replies
hi,
I want to import a revit file into navisworks and keep the same graphical when importing.. (the important problem I have is that I loose lines..)
Moreover I've a problem when I activate cut in naviswork on a volume : altough the volume is full in revit when I cut it in navisworks it's empty :
Thank for your help!
sabatierae
3 REPLIES 3
dgorsman
in reply to: sabatierae
Not sure about the first problem.  The second is how Navisworks operates - it "shells" the objects to surfaces which are easier to work with than volume-based solids.
sabatierae
in reply to: dgorsman
The first proble is that the model in naviswork is less precise than in revit. For example the front is composed by plates and We don't see it in naviswork because there are no line between two plates..
For the second problem can I do something?
Thx!
dgorsman
Nothing you can do about slicing solids at the moment.  There should be a feature request in the system, but there may be higher development priorities and future developments are never commented upon publicly.
Rail Community
