Dear Sir,
We are facing problem while imorting revit file in naviswork, we are not able to see Piles in naviswork files but it is there in revit files.I am attaching both the files for your reference. Kindly look into the matter ASAP.
Shankar Shirodkar
Dear Sir,
Shankar Shirodkar
Dear Sir,
Shankar Shirodkar
When I look at the files, Sample.nwd and Ford-1.rvt, the NWD doesn't look like it is coming from the Ford-1.rvt file (there is less geometry in the RVT file than in the NWD).
I tried bringing the Ford-1.rvt project into Navisworks, and I don't see missing geometry.
If you have not already done so, try bringing the Ford-1.rvt file into Navisworks on your system, and check for missing elements.
Also, make sure that the available updates have been installed for Revit and Navisworks.
Revit:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679039&linkID=16831210
Navisworks:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=10382102
