Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Transparent object in Navisworks
9 REPLIES 9
Message 1 of 10
bapan_b
9627 Views, 9 Replies
I have created some boxes in 3D model for access area, make it in different layer with 70% transparency. Shaded view of that model is showing as transparent object but when I load it in Navisworks it is showing as solid object.
What's the process to make transparent object in Navisworks?
15 Years Experience in Piping
9 REPLIES 9
Message 2 of 10
dgorsman
in reply to: bapan_b
Override item -> Override transparency.  With a little forethought for layer naming or other identifiers this can be automated using the appearance profiler.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 3 of 10
bapan_b
need detail steps
Message 4 of 10
danielkazado
Steps to follow is ;
 Select the item
 Right click
 Select Override Item
 Select Override Transparency
 Set the Transparency you want from the window.
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
Message 5 of 10
briancarp78
in reply to: danielkazado
How can this be done when creating the object in AutoCad?  I am uploading dwg's to a general contractor's BIM 360 Glue so I don't have ability to change in glue.  I want to make it transparent in AutoCad so all the other contractors see it as transparent without having to alter it in Glue.
Brian
Message 6 of 10
Kyle.ivie
in reply to: briancarp78
I would like to know how this is done as well, I need to know how to make objects drawn in Autocad show transparent in Glue.
Message 7 of 10
HEETESHC
I am doing the same but still model is not shown in transferency mode.
 Select the item
 Right click
Message 8 of 10
in reply to: HEETESHC
im actually trying to get the floor to go  transparent and it dont. any solutions
Message 9 of 10
Thanks for the solution but I have on query, Every time we append the .dwg transparent block, do we need to make this manually in Navis
Message 10 of 10
lohit_samotra
You might have already got the answer, but still if not. When you got to viewpoint>renderstyle>mode,. there is render mode options. if you drop down to shaded one, it will work.
Rail Community
