I have created some boxes in 3D model for access area, make it in different layer with 70% transparency. Shaded view of that model is showing as transparent object but when I load it in Navisworks it is showing as solid object.
What's the process to make transparent object in Navisworks?
Solved by danielkazado. Go to Solution.
Override item -> Override transparency. With a little forethought for layer naming or other identifiers this can be automated using the appearance profiler.
need detail steps
Steps to follow is ;
Select the item
Right click
Select Override Item
Select Override Transparency
Set the Transparency you want from the window.
How can this be done when creating the object in AutoCad? I am uploading dwg's to a general contractor's BIM 360 Glue so I don't have ability to change in glue. I want to make it transparent in AutoCad so all the other contractors see it as transparent without having to alter it in Glue.
Brian
I would like to know how this is done as well, I need to know how to make objects drawn in Autocad show transparent in Glue.
I am doing the same but still model is not shown in transferency mode.
@danielkazado wrote:Steps to follow is ;
Select the item
Right click
