Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Timeliner - Object Appearance / Animation
2 REPLIES 2
damo3
433 Views, 2 Replies
I see many Naviswork timeliner videos demonstrating the construction sequence of a building. I have managed to mock up a similar thing, the one thing I cannot work out how to do is control how those objects appear as the sequence progresses.
For example, I see timeliner videos where the columns extrude out of the floor as a visual effect during the animation. All my objects however, just appear with no fancy visual.
Can i control how objects appear / animate during the timeliner animation and how do i do this?
Thanks in advance for any assistance.
________________________________________________________________________________
If you find posts have solved your problem, please don't forget to mark them as 'SOLVED' to help others with similar questions. - Thank you.
__________________________________________________________________________________
2 REPLIES 2
dgorsman
in reply to: damo3
You need to use the Animator to create an animation sequence with the objects in question.  The sequence can then be assigned to the Timeliner task.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
damo3
in reply to: dgorsman
ok thanks, I will look into it.
Rail Community
