Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Timeliner Configure Settings
7 REPLIES 7
Message 1 of 8
Civil3DReminders_com
1249 Views, 7 Replies
I've searched through the forum and Google and can't seem to see if there is a way to export/import the Configure options for Timeliner. I can't imagine they would need to be created each time. Can anybody fill me in on the secret handshake?
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
7 REPLIES 7
Message 2 of 8
Create an NWD with all of you configurations set up in it, the use it like a template file.
open it first then append that file with all of you modeol files.
Message 3 of 8
I think it is not possible
I do this trick, have a empty navisworks file with that created, when i needed I used the "template file"
hope that help you
Cheers
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
Message 4 of 8
Thank you both for comfirming my initial fears of telling people about this feature.
Civil Reminders
Message 5 of 8
irhorta
in reply to: filipefrancisco
I know this topic is old, but how do you use that file like a "template" in navisworks? I create the nwd file setup in it, I tried append files in this file, I created a new file and append this file and others files, but did not work? Could you help me?
Message 6 of 8
The template is a prefilled file. Then open the file, do a save as, and then add stuff to it. You don't create a New file, reuse the "template" file as your starting point.
Civil Reminders
Message 7 of 8
Thank you for your reply,
But didn't work for me. When I append a file all settings disappear. I tried append the file that contains the settings firts, after I tried appended in last. I tried using a .nwf file and nwd file, but didn't work any way. Do you have any idea to hel me? I'm using Navis 2020 version.
Message 8 of 8
I can't, I don't have Navisworks 2020 installed to test or provide a video.
Civil Reminders
Rail Community
