I just received a Revit model from an architect that had a sweep at the top of the masonry walls for the coping. When I open the RVT in Navisworks or export a NWC from Revit, I only get the sweep and no wall. I removed the sweep and the wall comes through. I'm just posting this for anyone else that may stumble across the problem.
I'm getting the exact same issue a wall with sweeps built in will not come in to the revit model!!!!!!
Autodesk you need to fix this!!!
