Hi all,
I have a case here and could not solve it. I have imported surface from Landxml file and when viewed with object viewer, everything looks fine. However, when I 'NWCOUT' to Navisworks Manage, the surface does not appear at all. The model display at the style set to 'triangle'. There is no layer display in the Navisworks properties. Please help.
I'm having the same problem. Starting to suspect it is a memory issue because when I pull in surfaces from other projects that are smaller they pull in fine but with this one project, the surfaces are massive (3000+ acres) and either they don't come over at all or just the boundary shows with no way to render the TIN itself. I have tried NWCOUT and opening DWG, DWG or DWX directly with no success. Any help is appreciated.
Seems to be an issue I have come across twice this year so far. Still a problem in Civil 3D 2017?
