Hello there,
setting up an animation I got to notice there is a sudden jump between frames,
that has not been visible in the animations preview. It´s a standard Timeliner set-
up connected to a viewport anim. The animations play flawless when previewing
them. Also both of them are set to the same length. Interpolation of the saved
views is active. Do I need to adjust the angular speed manually?
I pretty much don´t know which options will allow me to achieve smooth playback
of all views. Sometimes this happens, sometimes it does not. It tends to happen mo-
re often after cuts than between regular view transitions.
I´ve attached a sample, as I said before, the preview does not show this "jump", only
the output does. Any information of how to solve this would be very helpful to me.
Kind regards
Daniel
Dogs aren´t flammable.
