Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Source File Name and Path in Properties Window
1 REPLY 1
kpennell
1722 Views, 1 Reply
Does anyone know if this is possible?
I'd like to be able to "right-click" on a property, and copy the path and filename to be able to paste the value in excel.  It does give the source filename, but not with the path.
KP
1 REPLY 1
Patrick_Aps_9121
in reply to: kpennell
Perhaps this could save you some time:
From the help of the FileToolsGUI.exe:
To generate a list of all design files used in the current model
1.In Autodesk Navisworks application, open the desired Autodesk Navisworks file, and click Home tab Tools panel Batch Utility .
2.The Autodesk Navisworks Batch Utility dialog box is displayed, and the path to the current model is automatically added to the Input area of the dialog box.
3.In the Output area, As Single File tab, click the Browse button.
4.In the Save Output As dialog box, browse to the desired folder, and enter the name for the text file.
5.In the Save as Type drop-down list, select the File List (*.txt) option, and click Save
Rail Community
