Is there a way to see a username in the properties. Be cool to be able to blame people instantly with proof... LOL!!
I used to see my usermae appear in the properties in version 2012.
Ideas?
Entirely dependant on the source data. If an object doesn't have a property for that it can't show up anywhere. You might try checking the file properties *but* that can changed easily enough. Best for everyone to be professional and accept responsibility for their models (unless you have rogue users peeing in someone else's digital flowerpots, in which case you have bigger problems).
Thank you for your poshttp://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794t. In this case I have not seen this before so I cannot say for sure. For reference I have included the development feedback link below. This is a direct link and will be captured by the development t team for investigation. This will help compel the need for this addition and share your story to discuss the business impact of the tool in its current state and the need for these changes. This helps and enables the team to consider this in a future update and full release. Thank you.DE
DEV Feedback: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
