Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Shift Key in Selection Tree Not Working
3 REPLIES 3
kpennell
629 Views, 3 Replies
Hello all,
Just wondering if anyone has experienced this, and hopefully have a fix for it.
In Navisworks 2012, with the selection tree expanded, at one point in time in earlier versions, I used to be able to select an item, scroll down, press the "SHIFT" key, select another item, and all items in between would be selected (identical to the behavior in windows explorer).
Now the only way to select multiple items, is to hold down on the "CRTL" key.  This is very time consuming when you a lot of selections to make.  Even longer, when during this selection process, you point and click between two lines items, and everything gets deselected.  Pain in the behind is what it is.
I've attached a jpeg of the screen shot of what I'm talking about.
Hopeful someone responds.
Thanks in advance,
KP
3 REPLIES 3
Patrick_Aps_9121
in reply to: kpennell
I have seen the same behaviour,
but when you click the bottom item first, then hold shift and scroll up and select the top item last,
in most cases this works for me.
Strange, but true...
kpennell
And I just found out something too.
It works if the first file you select is empty.
Weird.
Glad I explained it well enough.  Hope someone comes along with a fix.
Thanks for your time,
KP
benlewis1981
 I’m having the same problem but its seems to be available then unavailable at random times.
Rail Community
