Navisworks General Discussion
Valued Contributor
rnbhat
Message 1 of 4 (599 Views)
Shared Coordinates in Navisworks
599 Views, 3 Replies
12-09-2009 10:39 PM
When we export a revit model to nwc or nwd and import it in navisworks the location of the file as per coordinates is not same as that in revit.
At first we moved the model in navisworks to actual coordinates but the next time when we export the model from revit to navisworks it goes back to its original position.
Can any one give me a solution?
Raghavendra Bhat
Raghavendra Bhat
rnbhat1@gmail.com
Employee
timwiegand
Message 2 of 4 (599 Views)
Re: Shared Coordinates in Navisworks
12-11-2009 10:38 AM in reply to: rnbhat
Which versions of Navisworks and Revit are you using ? Support for Revit shared coordinates was added for Navisworks 2010, so if you are using an earlier version it might explain this problem.
Tim Wiegand
Software Architect
Navisworks
Autodesk, Inc.
Valued Contributor
rnbhat
Message 3 of 4 (599 Views)
12-11-2009 07:27 PM in reply to: rnbhat
I am using 2010 version. Can you please specify where I can find it in the navisworks interface.
Raghavendra Bhat
Raghavendra Bhat
rnbhat1@gmail.com
Employee
Sushichump
Message 4 of 4 (599 Views)
12-16-2009 10:47 AM in reply to: rnbhat
The shared coordinates option is actually in Revit. When you export as NWC, click on the Navisworks settings tab and select Shared from the Coordinates dropdown. See the attached image for more info.
Cheers,
Scott
Post to the Community
New Post
Announcements
Have API Questions?
New Dedicated Forum for Navisworks API
