Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
shading of Cadworx 2014 components
8 REPLIES 8
Message 1 of 9
1489 Views, 8 Replies
We have recently installed AutoCad 2014, Cadworx 2014 and Navisworx 2014.
The Cadworx "cadworx_plant_components"  do not shade (see attached) Note: the items that did shade are Autocad Solids.
Also, when selected the Cadworx attributes are not displayed in the properties box.
Is there a setting or fix for these issues?  Note: the selection settings.
8 REPLIES 8
Message 2 of 9
Patrick_Aps_9121
How do you create your Navisworks:
1) open the DWG in Navisworks 2014
OR
2) NWCout in CADworkx 2014 ?
What is your display style in AutoCAD when the DWG is closed. Wireframe ? Shaded ?
Message 3 of 9
dgorsman
in reply to: Patrick_Aps_9121
1. Check the Scene statistics.  This will probably notify you that you are missing the object enabler.
2. Ensure the object enabler is installed.  Doesn't hurt to re-install it.
3. Check the DWG Reader version.  The newer CADWorx versions with the OE-dependant objects are sensitive to this.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 4 of 9
  1. I open the DWG file
The drawing display style is usually wireframe sometimes shaded.
Message 5 of 9
in reply to: dgorsman
I have installed the enabler in AutoCad and it now displays properly.
This did not fix the NavisWorks display.
Is there a proceedure to install the enabler in NavisWorks?
Message 6 of 9
dgorsman
Not that I've seen.  Its just a matter of installing it with Navisworks already installed to ensure its properly registered.
Message 7 of 9
Thank you all.  We finally got the right file loaded and operating.
Message 8 of 9
tabgans
am also facing the same problem pls forward the link for autocad object enabler
Thanks & regards
Ganesan T
Message 9 of 9
willinsuite
Could you please explain how you were able to get CADworx 2014 to show properly in NAVISWorks?
Rail Community
