We have recently installed AutoCad 2014, Cadworx 2014 and Navisworx 2014.
The Cadworx "cadworx_plant_components" do not shade (see attached) Note: the items that did shade are Autocad Solids.
Also, when selected the Cadworx attributes are not displayed in the properties box.
Is there a setting or fix for these issues? Note: the selection settings.
Solved by dgorsman. Go to Solution.
How do you create your Navisworks:
1) open the DWG in Navisworks 2014
OR
2) NWCout in CADworkx 2014 ?
What is your display style in AutoCAD when the DWG is closed. Wireframe ? Shaded ?
1. Check the Scene statistics. This will probably notify you that you are missing the object enabler.
2. Ensure the object enabler is installed. Doesn't hurt to re-install it.
3. Check the DWG Reader version. The newer CADWorx versions with the OE-dependant objects are sensitive to this.
I open the DWG file
The drawing display style is usually wireframe sometimes shaded.
I have installed the enabler in AutoCad and it now displays properly.
This did not fix the NavisWorks display.
Is there a proceedure to install the enabler in NavisWorks?
Not that I've seen. Its just a matter of installing it with Navisworks already installed to ensure its properly registered.
am also facing the same problem pls forward the link for autocad object enabler
Thanks & regards
Ganesan T
Could you please explain how you were able to get CADworx 2014 to show properly in NAVISWorks?
