Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
shading of Cadworx 2014 components
8 REPLIES 8
Message 1 of 9
okiehawk2014
1483 Views, 8 Replies
We have recently installed AutoCad 2014, Cadworx 2014 and Navisworx 2014.
The Cadworx "cadworx_plant_components"  do not shade (see attached) Note: the items that did shade are Autocad Solids.
Also, when selected the Cadworx attributes are not displayed in the properties box.
Is there a setting or fix for these issues?  Note: the selection settings.
8 REPLIES 8
Message 2 of 9
How do you create your Navisworks:
1) open the DWG in Navisworks 2014
OR
2) NWCout in CADworkx 2014 ?
What is your display style in AutoCAD when the DWG is closed. Wireframe ? Shaded ?
Message 3 of 9
dgorsman
in reply to: Patrick_Aps_9121
1. Check the Scene statistics.  This will probably notify you that you are missing the object enabler.
2. Ensure the object enabler is installed.  Doesn't hurt to re-install it.
3. Check the DWG Reader version.  The newer CADWorx versions with the OE-dependant objects are sensitive to this.
Message 4 of 9
  1. I open the DWG file
The drawing display style is usually wireframe sometimes shaded.
Message 5 of 9
okiehawk2014
in reply to: dgorsman
I have installed the enabler in AutoCad and it now displays properly.
This did not fix the NavisWorks display.
Is there a proceedure to install the enabler in NavisWorks?
Message 6 of 9
dgorsman
in reply to: okiehawk2014
Not that I've seen.  Its just a matter of installing it with Navisworks already installed to ensure its properly registered.
Message 7 of 9
okiehawk2014
Thank you all.  We finally got the right file loaded and operating.
Message 8 of 9
tabgans
am also facing the same problem pls forward the link for autocad object enabler
Thanks & regards
Ganesan T
Message 9 of 9
willinsuite
Could you please explain how you were able to get CADworx 2014 to show properly in NAVISWorks?
Rail Community
