I have been using the Autodesk rendering option in Navisworks 2014 and I noticed that you do not have any control over the render quality when rendering from the output options or from the timeliner. When you render from the Render tab, you can specify Low, Medium and High as the Ray trace quality for interactive rendering. This is ideal when you want to output a draft quality still, but it is also to have a "quality" setting for animations as well. Is this by chance a final gather issue in the interals of the render or is that functionality not exposed in Navisworks?
