I have mistakenly floated my "selection Tree" pane off of the viewable area in Navismanage 2013. I have run a repair, and I have re-installed Navis, however, I cannot find my Selection Tree Pane. I have been able to use the "Find" pane to access the tree, but I would like it back. Any ideas on how to get it docked back in?
Adam
Solved by JeffH_ADSK. Go to Solution.
Is your Selection Tree actually on? Goto View/User Interface and check. If it is on, but "off screen somewhere", try changing you screen resolution.
Dennis,
Thanks for the input, I do indeed have it "on" and I have changed all available resolution levels with no luck. Just got a response from Autodesk today, it requires a "regedit" to fix. They have no other way to "fix" this when it happens.
Adam
Dennis,
They gave me a "regedit" link for Map3D that does the same thing, however, the instructions do not correlate to Navis. I have re-submitted the tech request..... I will post fix after it is done.
One thing to try would be resetting your Workspace. This restores all panes within Navisworks to a default layout.
To do this, go to the View section of the Ribbon, select Load Workspace and select one of the standard ones e.g. Navisworks Standard. This will reset all your UI layout, but you should find the Selection Tree is back & docked hidden on the left when activated.
Hope that helps,
Jeff
