Navisworks General Discussion
Active Contributor
mradamdavis
Message 1 of 6 (230 Views)
Selection Tree dissappeared - Help!
230 Views, 5 Replies
11-14-2012 11:25 AM
I have mistakenly floated my "selection Tree" pane off of the viewable area in Navismanage 2013.   I have run a repair, and I have re-installed Navis, however, I cannot find my Selection Tree Pane.   I have been able to use the "Find" pane to access the tree, but I would like it back.   Any ideas on how to get it docked back in?
Adam
Valued Mentor
dennis
Message 2 of 6 (209 Views)
Re: Selection Tree dissappeared - Help!
11-15-2012 06:50 AM in reply to: mradamdavis
Is your Selection Tree actually on?  Goto View/User Interface and check.  If it is on, but "off screen somewhere", try changing you screen resolution.
Active Contributor
mradamdavis
Message 3 of 6 (204 Views)
11-15-2012 09:53 AM in reply to: dennis
Dennis,
Thanks for the input, I do indeed have it "on" and I have changed all available resolution levels with no luck.   Just got a response from Autodesk today, it requires a "regedit" to fix.   They have no other way to "fix" this when it happens.
Adam
Valued Mentor
dennis
Message 4 of 6 (199 Views)
11-15-2012 11:10 AM in reply to: mradamdavis
Ouch, RegEdit....that is ugly.  What were you told to do?  For future reference should it happen to others...
Active Contributor
mradamdavis
Message 5 of 6 (195 Views)
11-15-2012 11:27 AM in reply to: dennis
Dennis,
They gave me a "regedit" link for Map3D that does the same thing, however, the instructions do not correlate to Navis.  I have re-submitted the tech request.....  I will post fix after it is done.
Employee
JeffH_ADSK
Message 6 of 6 (180 Views)
11-16-2012 01:25 PM in reply to: mradamdavis
One thing to try would be resetting your Workspace. This restores all panes within Navisworks to a default layout.
To do this, go to the View section of the Ribbon, select Load Workspace and select one of the standard ones e.g. Navisworks Standard. This will reset all your UI layout, but you should find the Selection Tree is back & docked hidden on the left when activated.
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
Have API Questions?
New Dedicated Forum for Navisworks API
