**EDIT... I SORTED THIS AS SOON AS I POSTED HAHA**
Another question for you lot 🙂
I want to be able to select a room/space inside Navisworks that was placed in the Revit file.
I want to be able to select, isolate and colour up rooms/spaces. I know i can create masses in the Revit file from the rooms with the API but im wondering if there is a "default" way to be able to select the placed Rooms/Spaces inside the Navisworks file.
I dont want to select the OBJECTS WITHIN the room, i want the "bounding box/3D space" of the room
Again, thanks in advance 🙂
Solved by Alisder.Brown. Go to Solution.
So, found the solution to this pretty much right away after posting the question haha
Solution was as follows:
Then once inside Navis, the rooms are now a selectable option in the selection tree
Hope this helps 🙂 Caused me a morning of frustration haha
