Heres a good challenge.
I've made a clash model. A model for the discipline to see their clashes easily. The viewpoints have everything hidden except for the catagories that pertain to the clash (Structural Framing model / Mech ducts Model). This was done choosing the save attribute function when you edit a viewpoint.
Here is the fun. My ducts were a set but I have recently divided the ducts up into their systems to make 4 sets. I have color coded them all differently. ( the old colour was orange for the ducts, the new colors are green, cyan blue and grey.) So after this update, I click on my saved viewpoint and all the ducts are orange again.
To combat this, I redid my efforts and updated the viewpoint this time, it seems to correct the issue. I have about 100 saved viewpoints, can this color correction be done globally?
Solved by lee.mullin. Go to Solution.
So one solution is to use the appearance profiler to correct the colors in each veiw then click update. Anyone have a one click fix?
You'll need to look into Hide/Required in the Viewpoint Settings, it's likely that this is currently switched off in each individual viewpoint so you'd need to go in and edit them to change this setting. More information can be found in the help guides
http://www.autodesk.com/navisworks-documentation
Let us know how you get on
