I have merged individual files (architecture, structure, MEP) and tried to show each items in separate viewpoints.
Firstly, I hide architecutre and structure showing only MEP then saved viewpoints by clicking the timeline with right mouse click.
Then unhide architecture and saved viewpoints by right clicking the previously saved viewpoints.
But viewpoints stay the same and every viewpoints I saved, changes to the current view I have.
Not sure whether I have explained it well but please reply if any of you know the answer.
Thank you
Solved by Patrick_Aps_9121. Go to Solution.
First, check your Options -> Interface -> Viewpoint Defaults: "Save Hide/Required Attributes" and "Override Material" should both be switched ON if you want that visibility is saved per viewpoint. If you have to change anything, close Navisworks and restart it in order to start with these settings.
Then delete all viewpoints and start over again.
Make everything visible, save viewpoint, set this as Home view in the viewcube
Make another view, with object hidden, save viewpoint.
and so on
BEWARE, if you want to change a saved viewpoint, right click on the name of the viewpoint, (without selecting it) and than choose UPDATE from the right mouse menu. Selecting it would re-load the old viewpoint and you would loose the new viewpoint you want to save.
