Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Save position of MEP parts in a database
5 REPLIES 5
Salbrox
434 Views, 5 Replies
Hi folks,
Does naybody know if it is possible to create a datatools connection to a database and for navisworks to save the position coordinates of each item of MEP into this database?
Any help much appreciated!
5 REPLIES 5
dgorsman
in reply to: Salbrox
Not sure if Navisworks will do what you are thinking.  It doesn't write any information to the database, its merely a lookup for additional information which isn't stored in the model.  For example a part number in the component would be used as a lookup index in an external database to pick up cost, vendor name, and lead time for ordering.
Salbrox
in reply to: dgorsman
Could there be a plugin that allows writing back to the database?
dgorsman
Should be possible.  Check the API board next to this one.
Salbrox
Right so i have been trying to get navisworks to connect to my database. It simply wont work for me. I'm getting the following error:
"Unable to set one or more links to active due to insufficient/invalid information. Setting them to inactive."
I'm trying to connect to a very simple table in a SQL server 2008 R2 database. This is my SQL:
"SELECT * FROM dbo.T_BIM
WHERE [Type]=%prop('Item','Type');"
This is the table:
T_BIM
ID  Type                    Comments
1    Duct                     123
2    Duct Fitting         456
3    Multi-View Part  789
Not sure why this is not working. I can connect with ms access no problem via odbc.
Salbrox
Tried doing this with a local sql express database and im still getting no joy. I really cannot find any help anywhere so it would be highly appreciated if anybody could shed some light on the issue. I cant see where im going wrong with this at all. Right now i just need to get the basic datatools linkup running.
Rail Community
