Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Revit Wall Type Not Visible
15 REPLIES 15
Message 1 of 16
smcgee
3915 Views, 15 Replies
I feel as if there is an easy solution and I'm just not seeing it, but.....
I'm working with an Architect's Revit Model and trying to pull it into Navisworks Manage. There is one wall type that is not showing up in Navisworks. The only thing different about this particular wall type is that it has an embedded wall sweep (water table) that is only present in this one type. I've checked the "Convert Construction Parts" option in the file reader section of Navis, but that didn't fix the problem. I've created a new 3D view in the Revit file called "Navis", and that didn't work. The only way I can manage to get the wall to show up in Navisworks is to change the "Convert" setting to "Entire Project", but I don't like the results when I do that. If I change the wall type in Revit to a different type without the water table, it works fine. I'm using Navisworks Manage 2014 and Revit 2014
Any thoughts?
15 REPLIES 15
Message 2 of 16
sburke
in reply to: smcgee
Getting same issue here with my files!!
Message 3 of 16
Lance.Coffey
in reply to: smcgee
An issue with missing elements (wall/sweep) exporting from Revit to Navisworks 2014 has been logged with our developers, and this is being investigated.
To see if the issue is specific to the particular sweep present in the wall type, try removing the sweep from the wall type.
If the wall type shows up in Navisworks when the sweep is removed, try adding a new simple sweep, to see if the issue was with the specific water table sweep.
Also, to ensure that the issue is not related to something in the existing project, try copying the original wall into a new project (using one of the default templates), and check if the issue occurs.
If it does (and if you can), please attach a copy of the new project, and I will forward it to our developers.
Lance Coffey
Technical Support Specialist
Message 4 of 16
sburke
in reply to: smcgee
Hello Lance,
This has been tested in default native Revit 2014 wall types nothing from past projects. In some cases the walls show but no sweeps and even worse sometime sweeps show but no walls. Essentially it is now impossible to use Navisworks 2014 on any Revit project until this is resolved. I hope the developers plan to work the weekend thus is an epic level bug right now.
Scott Burke | Building Solutions Team Manager
IMAGINiT Technologies
[Description: IMAGINiT--Black.png]
[Description: cid:image004.gif@01CB5A77.07DE7A60][Description: cid:image012.jpg@01CC9278.D977F530] [Description: cid:image006.jpg@01CB5A77.07DE7A60] [Description: cid:image007.jpg@01CB5A77.07DE7A60]
[Description: cid:image003.gif@01CB5A77.07DE7A60]
Message 5 of 16
smcgee
in reply to: sburke
Ditto....in my particular instance the wall sweep is showing up, but not the wall.
Message 6 of 16
Lance.Coffey
in reply to: smcgee
Service Pack 1 has been released for Navisworks, and one of the improvements listed is:
Issue where Autodesk Navisworks 2014 NWC exporter from Revit was missing elements for walls
Do you see a difference in this behavior after installing the update?
Lance Coffey
Message 7 of 16
ben.malone
in reply to: Lance.Coffey
I have the same issue and the latest service pack. I've tested it with a simple project with only a wall, and a sweep with the profile loaded from the default Autodesk library. What is the solution?
Message 8 of 16
ben.malone
in reply to: ben.malone
Was just making a video as an example and when I imported the swept wall, it appeared in Navisworks as I would expect! No idea what the solution was, but it's working now. Thanks.
Message 9 of 16
raaber
in reply to: smcgee
Same problem.  My other walls appear but my 6" Generic Walls with chair rail sweep do not show up. The chair rails show up indicating the walls are there but no wall.  Very frustrating. Please provide explanation and solution.
Message 10 of 16
fortunejohnny
in reply to: smcgee
I've updated the Navisworks service pack and re-exported to NWC.  The issue of the walls not appearing remains for me.  Did anyone ever reach a solution for this?
Message 11 of 16
Could you share the model (or at least a copy with the wall that doesnt show) for further investigation?
Thomas Schwaiger
Product Manager
Message 12 of 16
Thanks for the follow-up. I later realized that although I had updated Navisworks SP -- the exporters (add-in in Revit) was not updated. Once I updated the exporters as well, the problem went away. thanks again!
Message 13 of 16
GYSNG
in reply to: fortunejohnny
Have been using Navis 2015 trial and the wall / sweep visability bug is still not fixed.
Message 14 of 16
in reply to: GYSNG
Using Navisworks 2014 and this problem still persists. Has anyone got the solution??
Message 15 of 16
sburke
This was fixed in service pack 1 of Navisworks released in July of 2013.
Message 16 of 16
in reply to: sburke
thanks, i'll have a look and see what's going on as Navisworks 2014 was installed on my machine January 2014 so should have included this service pack.
Rail Community
