Hi everybody, When i sent a project in Revit to Naviswork, I have a problem with Id element : Railing in Revit is one element with one ID but when I sent project to Naviswork I found two element ID in Railing, Navisworks detach railing into two element with two IDs.How can I prevent railing in Revit export into 2 elements in Navisworks ? ( but Floor,beam and column don't change ID)
thanks your infomation, I think select correct railling, but I found a method to see element it.
Could you please show mw how to set up ID in Naviswork same as in Revit? Thank you
Làm ơn chỉ cho mình cách setup ID trong Naviswork va ID trong Revit giống nhau, xin cám ơn.
