Navisworks General Discussion
New Member
Hayson.C
Message 1 of 3 (684 Views)
Revit to Navisworks Element Parameters Lost
684 Views, 2 Replies
10-09-2012 08:54 PM
I have a project using Revit 2011, and our company has all series of Revit and Navisworks product from 2011 to 2013.
When I transfer the Revit 2011 file into Navisworks 2013 file, some of the instances lost some of their element properties. I do have check the "Convert element properties" and "Convert element parameters - All" in the Navisworks settings before transferring.
I have also tried using other version of the software or open the revit file direcly in Naviswork 2013, but none of the methods work.
Is there anything I am doing wrong? The file is attached.
I checked your file and I think what you need to do is change the "selection resolution" of the fitting when you select it.  I first got the same amount of properties you show, with the "selection resolution" set to "Last Object".  I then changed to "First Object" and receive alot more data.  Right-click on the fitting to set the "selection resolution".
Valued Mentor
dennis
Message 2 of 3 (666 Views)
Re: Revit to Navisworks Element Parameters Lost
10-10-2012 05:09 AM in reply to: Hayson.C
New Member
Hayson.C
Message 3 of 3 (634 Views)
10-11-2012 01:41 AM in reply to: dennis
Dear Dennis,
Thanks! Everything is OK now.
Best regards,
Hayson
Have API Questions?
New Dedicated Forum for Navisworks API
