When looking to upgrade to 2014 I went through a test run to see if these would be any issues. The first thing I notice is a huge issue - My exterior walls are missing!! I'm not sure why but as you can see from the attached pictures, there are no exterior walls - the white is in fact interior walls. (see 2013 image for what the model is supposed to look like). I played around with the Revit import setting but nothing changed. Even when using the NWC exporter from Revit the walls remained missing. The only thing I can presume happened is that Navisworks can't find the materials since there are little triangles in the material palette (see Materials image) however I feel as if this shouldn't delete the modeled element but rather display it as another color.
Any idea as to how to fix this? We obviously will not be upgrading until this issue is resolved.
I have a similar issue, my walls show up, but any embeded wall sweep is missing. Who knows what else could be missing. Since you need to manually add items into the new Quantification workbook rendering it...well scary, I'm going to be sticking with 2013 for a while!
I have a 3D view named NAVISWORKS. In that view, I have set-up my visibility and graphics so I can see what I want to see.
I also have your Navisworks Revit file reader setting to read the Navisworks view. I have had this setting for Naviworks 2012 and had no issues, but just installed REVIT + NAVISWORKS 2014 and now this is happening. Not all files, but some files are appear to be losing the exterior walls, this is the most noticable.
Any update on this ?
