Hi
i have received a couple of .rvt files that when appended into navisworks manage 2015 they import.complete with material renders applied. The models look great, but I am unable to change the appearance colour of items through selecting them.
Is is there a way to of switching the renders off so I can alter the appearance of items to highlight clashes/ markups etc
is is it a case of manually deleting the material libraries that have imported in the autodesk render window?
any help would be appreciated
mark
Solved by Patrick_Aps_9121. Go to Solution.
thats worked greats, thanks
I had switched off 'autodesk rendering', but hadnt toggled the viewpoint from 'render' to 'shaded'......
