I'm importing a number of RCS files created from Faro X330 scans. I would like to display them in Navisworks using a custom intensity ramp like I am able to do in Autocad and Recap. Is there any way to do this in Navisworks? I don't see an option in the Recap file reader.
Brian
Thank you for your post. One suggestion in this case could be to bring in the rcs file via Recap for translation prior to scanner direct to Navisworks. The RCS format is compatible but the step to included Recap or AutoCAD and then Navisworks could have message that transition of data. The only concern would be the settings as mentioned in your post. These may not transfer from this base product to Navisworks. The display may need to be manually adjusted within the Navisworks product, using the limited settings. Please test this and let us know in the community how this worked out. Thank you and we look forward to your reply
I created the RCS files in Recap. I think the problem is the limited display settings in Navisworks.
