Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
"Divided" walls from Revit 2012 won't show up in Navisworks 2012
1 REPLY 1
1040 Views, 1 Reply
Revit has a new tool in 2012 that divides a single element into parts, but still maintains an optional single identity of the object.  I've broken a wall into panels, exported the model to navisworks using the external tool for Navisworks Manage 2012, and upon opening the file in navisworks, the walls are not visible.
Are there settings I need to adjust?  I have not seen anything unchecked in my vg settings in revit.  Any help would be appreciated.
1 REPLY 1
lee.mullin
In the Settings in the Revit Exporter (where you select where to save your NWC) you will need to switch on 'Convert Construction Parts'.
More details can be found in this video
http://www.youtube.com/watch?v=Q0sp37GA1Gw
I hope this helps
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
Rail Community
