I have a Navisworks project where i setup the quantification in Metric units in Meters.
I would like to change that to Millimeter.
Also, can i set the decimal place for the values in the Quantification?
3 digit places for millimeter values is a little to much?
Best regards
Solved by scott.a.green. Go to Solution.
Hello!,
To change the display units:
1. Click Application Button > Options.
2. In the options editor, expand Interface > Display Units.
3. Select the units you want from the Linear Units dropdown.
Does this help?
From testing Navisworks out on my end with Takeoff, it doesn't appear that this is possible without reloading the project from before you set up quantification-takeoff and then setting it up again with the correct unit values.
