At times we open a model in 2015 and our 2014 Fabrication items are not there. Shut the model down and turn it on (sometime a dozen time) and the piping comes back. Even if we open the fabrication file by itself the fabrication items are not shown however what is detailed in standard ACAD is. All opbect enablers are installed and the fiel load is set at 2014. HELP!
I tried to erase all the nwc files. That didn't do it. My fabrication items still don't show in the model. I can't really make the model an nwd. since every file in the model is active (refreshes all day).
Oh yes, you can.
Just try it to see if it solves the problem. If it does, then you should find a way to automate it,
and than you have the choise between no items at all, or see the items with a delay of ... hours .
Ok---so I moved the "File Reader-dwg Loader Version" down to 2013. The problem seems to be solved. FOR NOW! The interesting thing is that Naviswork 2014 has this option set at 2014 and there are no issues.
