I am working on the field, using NavisWorks Freedom (2014) in a large-huge project. We need to print pipe systems and are not too happy with the print quality, we need to improve it. It seems bitmapped.
1) Is there a way to export/print vectorized graphics formats from NavisWorks Freedom (2014)? A matter of printer driver?
2) The printout/preview is usually is a bit larger than what is visible on the screen. Can this be adjusted?
3) Can the background collor / gradient pattern be omitted, just printing it plain white?
We can get good quality prints. Could you attach a sample so we can see specifically what you are referring to?
I am probably not allowed to publish anything so I attach an image that shows the print effect only. Thin lines will have staggered, fuzzy edges, as they are bitmapped.
I guess the issue is if the prints are always a screen dump, or if they can be exported in vector format?
(In that case, we could try other pdf generator / printer drivers...)
