I have some problems with insulation in nw2013. I can use nwcout commant in p3d and load the nwc-file. The insulation shows up fine. However, when using the normal way and load a dwg direcly into NW, the insulation doesn´t show up.
I have read some previous discussions regfarding this. Do anyone know if Autodesk has fixed this issue to 2013 version? Is there any good description on the matter?
Best regards
//Johan
