Why can I not edit my plan view using right click -> edit viewpoint? any thing I change does nothing and immediatly gets reset. The plan view is zoomed way out and is far too tiny to see anything with yet a bunch of wasted space around its perimiter. How, therefore do I zoom to extents in the plan view reference view? Currently the entire building only takes up about 5% of the screen space that I have alotted to it. thanks!
Solved by Patrick_Aps_9121. Go to Solution.
I appreciate your reply, however I dont think you understand my question fully. Please see attached image. I want #1 to look like #2. How do I do this? Thanks again!
Ok, i misunderstood.
But what works over here in Simulate 2015 SP3 is the following:
navigate around in your main view until you see what you would like to see in the "Plan View window"
Save that viewpoint
Navigate to the "Plan View window", Right click above it -> Look From -> Current viewpoint.
Navigeate in the main view until you see something else
SAVE your NWF or NWD (I did the test saving as NWD)
I closed Navisworks and opened the NWD again and the "Plan View window" held the view that I wanted.
