I used to work with SmartPlant Review and there was an option to add scaffolds. Basically, it was just an editable volume that we can add in the model. I put an example in attachment. Is there an equivalent in Navisworks?
JF
Solved by lee.mullin. Go to Solution.
There is no such function in Navisworks. In fact, Navisworks does not create any kind of geometry entities.
Just as a quick addition, if you create volumes in your native application and name them scaffolding, or crane movement, then these can be Appended to the model and used as volumes in Timeliner or Clash detective. Using the appearance profiler you can easily make any of these volumes semi transparent or change their appearance.
