Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Pipe display problem
4 REPLIES 4
1234 Views, 4 Replies
Hi, there
I opened a .dwg file of Plant 3D 2012 in Navisworks Manage 2012. In the .dwg file, i have serval pipes.
Here is the problem: in Plant 3D all pipes look ok, but in Navisworks all pipes look like polygon cylinders, which should look like cylinders.
How can i do to make my pipes look like cylinders in Navisworks? Anyone knows ahout it, pls help me.
See the attched image if i did not make myself clear.
Tags (1)
4 REPLIES 4
Problem solved.
I am having this issue. could you explain the solution to this please?
Stassel
snijdam
Could you tell us how you did solve the problem? Same issue here...
tstright
in reply to: snijdam
I beleive the OP found the layers were turned off in the orginal file that was being xref'ed.
He couls see them in the model but navis was not.
"Only the Skilled Survive"
Rail Community
