Navisworks General Discussion
luoyong20061289
Message 1 of 5 (790 Views)
Pipe display problem
790 Views, 4 Replies
12-29-2011 07:39 PM
Hi, there
I opened a .dwg file of Plant 3D 2012 in Navisworks Manage 2012. In the .dwg file, i have serval pipes.
Here is the problem: in Plant 3D all pipes look ok, but in Navisworks all pipes look like polygon cylinders, which should look like cylinders.
How can i do to make my pipes look like cylinders in Navisworks? Anyone knows ahout it, pls help me.
See the attched image if i did not make myself clear.
Problem solved.
luoyong20061289
Message 2 of 5 (782 Views)
Re: Pipe display problem
12-29-2011 09:05 PM in reply to: luoyong20061289
Problem solved.
Stassel
Message 3 of 5 (594 Views)
07-18-2012 12:46 PM in reply to: luoyong20061289
I am having this issue. could you explain the solution to this please?
Stassel
Active Contributor
snijdam
Message 4 of 5 (533 Views)
08-13-2012 06:10 AM in reply to: luoyong20061289
Could you tell us how you did solve the problem? Same issue here...
Active Contributor
tstright
Message 5 of 5 (450 Views)
09-27-2012 04:01 AM in reply to: snijdam
I beleive the OP found the layers were turned off in the orginal file that was being xref'ed.
He couls see them in the model but navis was not.
"Only the Skilled Survive"
Have API Questions?
New Dedicated Forum for Navisworks API
