When we convert PDMS(.rvm) in Navisworks, basically PDMS obstructions are included in NWx like attachment.
So, in case they overided the object that I want to see in properties, although I try to select the object,
I can not see properties without hiding obstrcutions individually.
Could you please add one in .rvm file readers options such as switch on-off obstruction?
Thank you.
hi,
I've been using the method of defining colors from pdms to navis, but i can't figure out how to set the transparency automatically,
I would like to set certain items such as volumes and access to be transparent when I extract from pdms,
may i ask the procedure on how to do it?
thanks!
