I loaded an Inventor assembly into Navisworks Manage 2014 but some parts are not loaded. They are not in the model tree in Navisworks. It concerns content centre parts (bends and tees) used in the tube and pipe environement in inventor. The pipe and other fittings are succesfully loaded. See the picture below.
I've updated Navisworks 2014 with the service pack on october 11th. Before the update it used to work correctly.
When parts don't show up in Navisworks, my first port of call is the Scene Statistics report. That should tell you if they are actually found, and if there was any problems loading them.
See below the Scene Statistics Report. I don't know what to make of that.
btw I use Naviswork Manage 2014 from the Factory Design Suite
Neither do I, unfortuneately - thats unreadable here. Have a look at whats being loaded. Does it include what you are looking for? Does it say anything about "Can't find..." or other error messages?
I've found the solution! In the file reader for Inventor files the path to the project file wasn't set. Therefor Navisworks can't find all parts that are stored in the content centre.
Anyway thanks for your thoughts.
