Overriding the colour of object works, but does not apply shading.
I am using the following code to override the elements passed in the ModelItemColection variable called "items". This works but for some reason it does not apply shading to the items. I am using the below code to change the colour of the items:
Dim newColor As New Autodesk.Navisworks.Api.Color(255, 0, 0)
'Override the Color
Autodesk.Navisworks.Api.Application.ActiveDocument.Models.OverridePermanentColor(items, newColor)
As you can see from the below image it applies the colour, in this case RED, but no shading:
However it I do it through the Navisworks forms it works, see image below:
It's as if I need to tell Navisworks to apply the rendering to the active document agian?
Can anyone offer some assistance.
Simon
Solved by tim.wiegand. Go to Solution.
Hi Simon,
In computer graphics, colour isn't as simple as a single shade. There are different components that can be specified to control:
1) the ambient colour (a base colour that shows whether it is illuminated or not)
2) the diffuse colour that interacts with light but is totally matte
3) the colour for specular (shiny) highlights
Your completely red objects look as if they have had all the colour applied as a ambient colour. So they appear completely red irrsepective of the light direction. This is why they look flat.
The NW UI is almost certainly doing something more sophisticated than that API call currently does.
There's three possibilities here:
1) there may be a more sophisticated API you could use (I had a quick look and nothing leaps out in "Models", I do not know whether there is public API for controlling Autodesk Rendering in NW, but if there is then that would certainly permit more sophistication)
2) or this could be a bug, and it may be that OverridePermanentColor is supposed to set a mix of ambient and diffuse color (what happens if you use less than 256 red?)
3) or, if this is behaving as expected, you could make an enhancement request for an improved override method
I am asking a colleague what the expected behaviour is here...
I realise I haven't actually solved your problem, but I hope that something in here might help move you forward.
Ian
Ian,
Thank you for your reply, some good points there.
However, even if I use a different colour, or ensure it is not a true primary colour i.e. instead true RED a variation, it still does not display any type of shading. The thing is that when using the Naviswork GUI it works, even if I use true RED, I can only assume that it must be calling some class after overriding the colour to get Navisworks to re-apply shading to components. I don't know if this is the case, or how to do it, it must be in the source code for Navisworks???
I will keep looking through the API to see if there is anything else that can help me, but like you found nothing jumped out.
If you could let me know if you get anymore info, as this is quite important as I am writing a plugin for a big client, and obviously cannot supply it with the current method of colouring as you cannot see any definition on model elements.
What about a different approach of creating custom materials e.g. a material which is RED, and then applying this material to item instead of colour? Don't know if this is even possible, just thinking out load. If it is do you have some sample code?
Thanks for your help
Simon
Check the documentation for the Color class. In Navisworks the R, G and B parts of a color are defined as floating point values in the range 0.0 to 1.0. A color of (1,0,0) should do what you want.
Tim,
Actually saw that a bit ago and was just testing, and I can confirm you are correct this solved the issue. Thanks for all your help guys.
Simon
Hiya,
I had a quick look at this and was unable to reproduce it. Calling the API function did just the same as using the UI. Can you provide a sample model and some source code that reproduces this issue?
Michael
