Hi
Can someone tell me how to make my pipework look non hexagonal when viewing in NWnavigator, I am using Plant 3d 2012 and Navis Manage 2012.
I have tried all the right click options in NWnavigator and played around with options in Navis.
The annoying thing is - we had solved this some time ago but have a new starter and cannot remember the solution.
Any help would be greatly appreciated.
Kindest Regards
Darren Goodman
Navigator uses the Navisworks viewer and the DWG exporter internally, so you should be able to control the faceting in the same manner as in Navisworks proper. Probably the first starting point would be to change the exporter's faceting factor in options, accessed by typing nwopt in the AutoCAD command line.
Hope that helps,
Jeff
